megafunction problem
im using quartus 7.2sp3 and im a new user. when i tried to use the megafunction plug in manager,after attempting a few steps, the entire quartus will be jammed and it will eventually exit by itself.
Why don't you upgrade to Quartus II 8.0 sp1?
Which mega-function you tried? Or better you switch to Quartus II 8.0 as suggested by OrchestraDirector
I've had the problem that I couldn't open the mega function wizard from SOPC builder. I think it was becasue of the search path to the project had spaces in it. I can not remeber which version this was, after this I never used spaces in my project names so I don't know if it is still there.
my pc at my workplace is installed with quartus 7.2sp3 but does not have this problem like my home pc does...
A conflict may occur due to some wrong operation of the OS, so I strongly recommend you to install the 8.0 version and try again.
alright, i will give a try...thanks alot!
