17256 Discussions
Source FILE not found error-PCIE MCDMA Example design VCS simuation
Chellambalaji
Hi team,
I am using Quartus20.3 tool to generate example design for PCIe_MCDMA gen3x16.
After generated,i go to the "project_name/pcie_ed_tb/pcie_ed_tb/sim/synopsis/vcs" path and set VCS_HOME for VCS-P2019.06-SP4.
While i run the vcs_setup.sh, facing the source file not able to open for reading.
Its shows that inside the path /tools/intel/intelfpga/20.3/quartus/eda/sim_lib/synopsis/ct1_hssi_atoms_ncrypt.sv
File was not there.
Kindly check the below error message and help to resolve this issue.
Chellambalaji
BoonT_Intel
Hi Sir,
I check my Quartus installation directory and I can see the file ct1_hssi_atoms_ncrypt.sv. the size is a few hundred MB, thus I can attach it here. Maybe you should try to re-install or give it a try on another Quartus version.
I also tried to run the simulation and it is successful.
BoonT_Intel
Hi Sir,
