17255 Discussions
How to enable the pull-up feature of some IO pin of Stratix III
OCn
Hi!
I'd like to use TCL script to enable the pull-up feature of some IO pin of Stratix III. Could any one tell me how to do this, or where I can find any document about this?
sstrell
This would be an assignment that you'd put in a script or add to the .qsf file.  You can see examples of assignments in this document with I/O-related examples in section 1.2.3:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qps-design-constraints.pdf
Search the built-in help (Logic Options section in the help table of contents) for the assignment(s) you want to use.  You could also create the assignment in the Pin Planner then look at the .qsf file to see the formatting and use that in your own scripts.
sstrell
OCn
Hi sstrell,
OK, I understand.
Thanks for your reply and providing these information!
Oliver
