17267 Discussions
Specification fullfilment, check differences between versions, bug control, version control... is there anyway you can perform a full development tracking using an Altera or third party tool?
NNort1
MEIYAN_L_Intel
Hi, Based on my understnding, the question you asked is about the differences between quartus versions and issues resolved between each version, am i right? If yes, I had found out there are some release notes provided for different version of quartus with some updates and issues resolved. The links as below : Quartus II v14.0: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn_qts_140up2_dev_support.pdf Quartus II v15.0: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn_qts_150up_dev_support.pdf Quartus Prime v16.1: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn_qts_161up_dev_support.pdf Quartus Prime v17.1: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn_qts_dev_support_update-17-1-2.pdf Quartus Prime v18.0: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/archives/rn_qts_dev_support_update-18-0-1.pdf Quartus Prime v18.1: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn_qts_dev_support_update.pdf Also, there are some release notes of device support in each quartus versions. This is because some of the version may only support to certain devices. The links as below: https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html Thanks
NNort1
Thank you for your response but it seems I wasn't clear.
I am talking about creating new releases of your own software programmed in Quartus.
Is there any way to track the differences between each release?
MEIYAN_L_Intel
Hi, I am not clear about the mentioned word in "new release". Do you means new feature nor bug fixed differences in each Quartus version or do you means you need to track the differences of designs while using the Quartus software? Can you explain more to me? Thanks.
