17252 Discussions
Starting up with DEO-Nano-SoC board
hi
I'm using the board DEO-Nano-SoC kit and I'm trying to install the OpenCL tools on the board.
After reading the manuals "Altera SDK OpenCL - Getting Started Guide", "Altera RTE for OpenCLGetting Started Guide" and "Altera SDK for OpenCLProgramming Guide" I've tried the following plans:
1º:
Go to c:altera/16.0/hld/broad/c5soc/ and try to install the fille "linux_sd_card_image" but after decompressing the tar fille the image in SD card doesn't boot.
2º:
Use the linux available in rocketboards site (https://rocketboards.org/foswiki/view/documentation/atlassocsdcardimage) and try to untar the previous fille, "linux_sd_card_image", but the linux version is different from the OpenCL libs, therefore it complaints about different kernels.
I'd like to request assistance setting up OpenCL on the DEO-Nano-SoC board.
Thx
I am also having trouble with this, there is one demo that uses OpenCL on the DE0 that provides sources. I'm not experienced with embedded Linux though and haven't managed to build anything functional yet... maybe you will have better luck.
https://rocketboards.org/foswiki/view/projects/openclmandelbrotdemoonatlassoc
Any updates on this topic? also having the same problem related by the author of this topic.
