17264 Discussions
Startup problem with Questa Simulator.
CHatz
When I invoke Questa, it displays the following message:
I downloaded the latest version from the Quartus Lite package, and I still get the same message.
Any ideas or suggestions?
ShengN_Intel
Are you using window version? Does the supported OS environment being used? Are you invoking questa straight away from vsim.exe? I had tested without problem check attached. May be try to re-install.
Sheng
ShengN_Intel
Do you have any further concern or consideration?
Sheng
RichardTanSY_Altera
Do you able to resolve the issue?
Richard Tan
