17265 Discussions
State Machine File Tutorial??
I'm new to using State Machine Files for design. Creating the FSM was easy, but I want to compile and implement. I'm using Quartus 9.0 with DE2 Boards. I have questions:
1) Is there a tutorial walking you though designing and implementing using .smf?
2) If I want to use both .smf and .bdf files in my project, how do I connect it all together?
thanks
The Quartus II software saves the state machine diagram as a State Machine File (.smf). After defining the state machine logic, you can create a Verilog HDL or VHDL design file by clicking the Generate HDL File icon. You can then instantiate the state machine in your design using any design entry language.
