17252 Discussions
State Machine - define an initial state
Hi, so I'm doing this activity and I have to make a controller, but it does not have a reset or any input. It have to start the moment I put power on the circuit. Here comes the problem, when I try to simulate (an example of my code is below) it starts on a different state (not the one i want). I know why it's wrong, I just don't know how to fix, how to tell - in VHDL - which one is my initial state.
example of my code:
architecture beh of FSM is
type states is (Initial_state , second_state , third_sate );
signal EA: states;
begin
process (clock, EA)
begin
if clock'event and clock = '1' then
Case EA is
when Initial_state =>
EA <= second_state;
when second_state =>
EA <= third_state;
when third_state =>
EA <= Initial_state;
end case;
Thank you!
in VHDL, any signal without an initial value will initialise to type'left
So in this case, the EA signal will start with the "initial_state" value
for simulating i think you can define it when you create the signal i.e.
signal EA : states := Initial_state;
or
signal EA : states := Second_state;
depending where you want it to start
--- Quote Start ---
or
--- Quote End ---
That should also affect the power up state of the state registers during synthesis - but it's just easiest to leave it to initialise to the left most defined value.
thank you guys for your answers, really helpful.
