17252 Discussions
What is the best approach to do pin assignments for DDR?
I have a design which use the Altera DDR3 Sdram controller IP to interface with the external DDR3 in board. The board I am using is Altera evb dsp development kit, stratix v edition (http://www.altera.com/products/devkits/altera/kit-stratix-v-dsp.html).
After I made the design, I try to do pin assignments in Pin Planner. After I setup all pin locations and I/O standard, then run the design during fitter, I got bunch of errors which seems to be similar, that I didn't use the calibrated on-chip termination. In the board dev kit, there are memory example design, when I do the pin assignments, I opened the ddr3x72 example design and compared its pin planner with mine. I can see them same. But when I open the qsf file of the example design, I can see:
set_instance_assignment -name IO_STANDARD "SSTL-15 CLASS I" -to ddr3_dq[51] -tag __ddr3_x72_qsys_mem_if_ddr3_emif_0_p0set_instance_assignment -name INPUT_TERMINATION "PARALLEL 50 OHM WITH CALIBRATION" -to ddr3_dq[51] -tag __ddr3_x72_qsys_mem_if_ddr3_emif_0_p0
set_instance_assignment -name OUTPUT_TERMINATION "SERIES 50 OHM WITH CALIBRATION" -to ddr3_dq[51] -tag __ddr3_x72_qsys_mem_if_ddr3_emif_0_p0
for most of pins, it set the input and output termination. I didn't see this option in pin planner. So does this means I have to write tcl into my project qsf file to configure the termination for all the pins? Is there any other better approach to do the pin assignments for the DDR3 interface?
Thanks in advance.
For simple projects, you're only responsible for pin location assignments.
There is an automatically generated .tcl file which applies those constraints for you. You need to run that script (once).
http://www.altera.com/literature/hb/external-memory/emi.pdf
Review "Table 2-1: Design Checklist" and then search for "pin_assignments.tcl" elsewhere in the document for additional instructions.
Manually looking for and changing those assignments within the GUI is done in the "Assignment Editor", not "Pin Planner".
--- Quote Start ---
--- Quote End ---
Thanks, ted. I read the table 2-1. t mentioned:
Add pin settings andDQgroup assignments. The wizardgenerated . tcl file includes I/O standard and pin loading constraints to your design. I made my design using Qsys. In the generated directory synthesis\submodules, I found several tcl file which are related with sdram IP, which includes :
make_qysy_seq.tcl
parameters.tcl
pin_assignments.tcl
pin_map.tcl
report_timing.tcl
report_timing_core.tcl
timing.tcl
I think "pin_assignments.tcl" is the one I need to run the Quartus ?
Download and look at bemicro_cv_examples.zip from Post#5
http://www.alteraforum.com/forum/showthread.php?t=43992
You can setup your Quartus project with a flow-script that runs the script generated by the DDR3 IP core generator. That way you do not "forget" to run the script.
Cheers,
Dave
Thanks, I will check it.
