17255 Discussions
State machine fail to hold default value
Hi, all
Here's example of my state machine coding in verilog:
--- Quote Start ---
always @(posedge clkADC or posedge RST)
begin
if (RST)
state <= s0;
else
case (state)
s0: if (START) state <= s1; else state <= s0;
s1: ns <=s2;
s2: ns <=s3;
s3: ns <= s0;
endcase
end
always@(state, DataIn)
begin
case (state)
s1:begin
fifo_wreq <= 1;
Data <= DataIn;
end
s2:begin
Data <= DataIn;
end
s3:begin
Data <= DataIn;
fifo_wreq <= 1;
end
default:begin
Data <= 12'b000000000000;
fifo_wreq <= 0;
end
endcase
end
--- Quote End ---
fifo_wreq at s2 suppose to be default value, which is 0. However, I found out that it remain 1 at state machine s2. May I know any mistake i do so far?
You didnt assign it to 0 in s2. In the second always block, you need to assign all values in all states.
S1 will occur before s2, therefore fifo_wreq has already been set to 1 in the previous state. You created a latch (which is not a good thing) but letting it remember it's value between states.
Hi, Tricky
Thanks for reply. For my understanding, if I didn't assign fifo_wreq to 0 in s2, suppose fifo_wreq value is followed by the default value as stated 0. Am I right?
May I know how to prevent the latch happen?
--- Quote Start ---
Hi, Tricky
--- Quote End ---
No, once you assign a value to a variable, it stays at that value until it is assigned again
--- Quote Start ---
--- Quote End ---
Ensure all variables are assigned in all cases in non-clocked always blocks. They should preferably be assigned with non-blocking assignments..
--- Quote Start ---
--- Quote End ---
Variables in a non-clocked always block should be assigned with blocking assignments.
Clocked always blocks should use non-blocking assignments.
