Hi, all
Here's example of my state machine coding in verilog: --- Quote Start --- always @(posedge clkADC or posedge RST) begin if (RST) state <= s0; else case (state) s0: if (START) state <= s1; else state <= s0; s1: ns <=s2; s2: ns <=s3; s3: ns <= s0; endcase end always@(state, DataIn) begin case (state) s1:begin fifo_wreq <= 1; Data <= DataIn; end s2:begin Data <= DataIn; end s3:begin Data <= DataIn; fifo_wreq <= 1; end default:begin Data <= 12'b000000000000; fifo_wreq <= 0; end endcase end --- Quote End --- fifo_wreq at s2 suppose to be default value, which is 0. However, I found out that it remain 1 at state machine s2. May I know any mistake i do so far?Link Copied
You didnt assign it to 0 in s2. In the second always block, you need to assign all values in all states.
S1 will occur before s2, therefore fifo_wreq has already been set to 1 in the previous state. You created a latch (which is not a good thing) but letting it remember it's value between states.- Mark as New
Hi, Tricky
Thanks for reply. For my understanding, if I didn't assign fifo_wreq to 0 in s2, suppose fifo_wreq value is followed by the default value as stated 0. Am I right? May I know how to prevent the latch happen?- Mark as New
--- Quote Start --- Hi, Tricky Thanks for reply. For my understanding, if I didn't assign fifo_wreq to 0 in s2, suppose fifo_wreq value is followed by the default value as stated 0. Am I right? --- Quote End --- No, once you assign a value to a variable, it stays at that value until it is assigned again --- Quote Start --- May I know how to prevent the latch happen? --- Quote End --- Ensure all variables are assigned in all cases in non-clocked always blocks. They should preferably be assigned with non-blocking assignments..
--- Quote Start --- No, once you assign a value to a variable, it stays at that value until it is assigned again Ensure all variables are assigned in all cases in non-clocked always blocks. They should preferably be assigned with non-blocking assignments.. --- Quote End --- Variables in a non-clocked always block should be assigned with blocking assignments. Clocked always blocks should use non-blocking assignments.
