17261 Discussions
Store the data on the EPCS4!!
Hello ,I want to keep the data to the EPCS4,following is the process:# include <stdio.h># include <unistd.h># include "system.h"# include "alt_types.h"# include "sys/alt_flash.h" # include "sys/alt_flash_dev.h"# include "altera_avalon_epcs_flash_controller.h"
alt_u8 epcsbuf[32]="123456789";
int ret_code,i;
int number_of_regions;
alt_flash_fd* my_epcs;
flash_region* regions;
int main (void) __attribute__ ((weak, alias ("alt_main")));
int alt_main(void)
my_epcs = alt_flash_open_dev("/dev/epcs_flash_controller");
ret_code = alt_epcs_flash_get_info (my_epcs, &regions, &number_of_regions);
if(my_epcs)
ret_code = alt_epcs_flash_erase_block(my_epcs, 0x70000);
ret_code = alt_epcs_flash_write(my_epcs, 0x70000, epcsbuf, 10);
for(i=0;i<10;i++)
epcsbuf[i]=0;
ret_code = alt_epcs_flash_read(my_epcs, 0x70000, epcsbuf, 10);
while(1)
return 0;
Why is red part of the function return value is 0?And the address of the EPCS4 is absolutely correct.
What about the name? Are you sure that the controller name is /dev/epcs_flash_controller ? You can look for it in your system.h
you can pick up the macro EPCS_NAME (something like that) from your system.h
