17261 Discussions
Subprograms for bus functional model
I have a problem that is driving me crazy! I hope someone can help me.
I am trying to make a bus functional model for simulation and using VHDL 2008 is fine.
The subprogram interface should look something like:
bfm_read(address,read_data) or read_data=bfm_read(address)
bfm_write(address,write_data)
These subprograms will be used in a testbench so somehow these subprograms must manipulate the bus signals for the entities instantiated in the testbench.
I should add I have done it by making an entity bfm and defining a procedure in the stimulus process in the testbench. But I would like to somehow move the subprograms to the bfm to make the it more modular.
I have looked into protected classes but I can't see how to connect the bfm bus signals using that approach.
Thanks!
You can create VHDL BFMs using two main techniques;
1. An array of global signals, eg., see the Altera Avalon-MM BFM source code and tutorial I wrote (link to PDF and source on this page)
https://www.ovro.caltech.edu/~dwh/correlator/cobra_docs.html
2. Use a resolved signal and pass that as an extra argument
Download
https://www.ovro.caltech.edu/~dwh/correlator/pdf/esc-104code_hawkins_2015.zip
and look at the Avalon-MM BFM code I wrote in
ESC-104Code_Hawkins_2015.zip\dsp_tutorial\vhdl\lib\packages\test
ESC-104Code_Hawkins_2015.zip\dsp_tutorial\vhdl\lib\altera_avalon\test
If you've ever written "object-oriented C code" you'll appreciate that the resolved signal is acting like a reference to the BFM.
Cheers,
Dave
you can manipulate signals in a procedure. E.g.
PROCEDURE ChangeOutputAfterClock( SIGNAL iSysClk : IN STD_LOGIC; SIGNAL oSource_Data : OUT STD_LOGIC_VECTOR(7 DOWNTO 0); ) IS BEGIN -- initialize all output values oSource_Data <= (OTHERS => '0'); -- wait for one clock cycle to process WAIT UNTIL RISING_EDGE(iSysClk); -- change output value oSource_Data <= (OTHERS => '1'); END PROCEDURE;
