library IEEE;
use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; . . . signal count_val : std_logic_vector(5 downto 0) := "000000"; . . now what should the answer be if I do try to subtract 1 from the logic vector when it is 0? What shall the value be if I add 1 to it when its value is already "111111"?Link Copied
std_logic_vector is undefined in terms of mathematical value until you either ask compiler to interpret as either signed or unsigned.
if signed: 000000 + 1 => 000001 000000 - 1 => 111111 (-1) if unsigned: 000000 + 1 => 000001 same as above 0000000 -1 => illegal (-1), what you get is up to tool if allowed if the tool does let you add/subtract on std_logic_vector then it is using default and is not safe.- Mark as New
Over/underflowing is a perfectly normal behavior when using a bit type, and no tool should throw an error (I dont know how you would synthesis a checker for it anyway without specifically building one).
Integer on the other hand will not overflow in simulation, you'll get an error, but on an FPGA it will overflow.- Mark as New
I was trying to create an up/down counter. I am getting confused what will come if I do (-1) on std_logic_vector when it already is equal to "000000". What value should I expect to be detected if do (-1) and than try to do unsigned() of the result in an if statement?
I agree with Tricky. Underflow and overflow occurs naturally when perform add and substract operations. If you perform a simulation with Model Sim you see that "0000" - "0001" gives "1111" ( underflow ). Try the testbench:
uut : entity work.sumador_2 port map( a => tb_a, s => tb_s ); process begin wait for 1ms; for i in 0 to 15 loop tb_a <= std_logic_vector(to_unsigned(i, 4)); wait for 1ms; end loop; assert false report "Fin de la simulacion" severity failure; end process; Where sumador_2 is: architecture data_flow of sumador_2 is begin s <= std_logic_vector( unsigned(a) - "0001"); end architecture data_flow;
