17252 Discussions
Symbol Editor - "Save as.." not working for files in libraries used with relative paths
HBirk
I am using designs with schematic diagrams as Top-Level.
When I use the Symbol Editor by right-clicking a symbol and selecting "Edit selected Symbol" I cannot the symbol with a new name by using "File" > "Save as..". The expected filemanager window (where path and filename can be entered) does not appear.
This is the case for symbols in libraries that are used with relative paths in my projects.
For symbols in libraries used with absolute paths the "Save as.." works fine.
Tested with Quartus Prime Lite 21.1.0, 20.1.0 and 19.1.0. under Windows 10.
ShengN_Intel
The top-level schematic diagrams bdf file must be in same directory or folder with the symbols in libraries that are used with relative paths. Then only the problem mentioned above can be solved.
Hope it helps.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
ShengN_Intel
Hope it helps.
Sheng
HBirk
That's too bad. In older Quartus Versions (e.g. 14.1.0) the "Save As.." functionality is working fine, even if the toplevel and the libraries (used with relative paths) are not in the same directory.
So my workaround will remain using an outdated Quartus Version in order to create symbols derived from existing files.
