17241 Discussions
Synthesis error in VHDL process
I am trying to implement clock synchronizer and clock divider in the following piece of VHDL code. The clocks(clk_rx and clk_tx) should synchronize at the rising and falling edges of 'RX' signal on the bus. I can simulate the following in Modelsim but it is not synthesizable in ISE since i am using " RX'EVENT ". Could any one suggest an alternative for this? (vhdl or verilog)
-------------------------------------------- CLOCK DIVIDER----------------------------------------------------------------------------------------
PROCESS (CLK_I, RX)
BEGIN
IF (RX'EVENT) THEN
clk_cnt <= to_unsigned(0,clk_cnt'LENGTH);
ELSIF (CLK_I'EVENT AND CLK_I = '1') THEN
IF clk_cnt >2499 THEN
ELSE
clk_cnt <= clk_cnt + 1;
END IF;
END IF;
END PROCESS;
clk_rx <= '1' WHEN clk_cnt = 1250 ELSE '0'; -----clk_rx=1 only at the half of the counter period----------clk enable
clk_tx <= '1' WHEN clk_cnt = 2499 ELSE '0';
you cant detect both edges of the RX signal, you are only allowed to detect a single rising or falling edge, and us it as the clock - not in addition to another clock.
What is RX? is it really a clock or some other signal? usually you would create an edge detector by comparing a registered version of a signal to the signal itself.
It simulates fine because lots of VHDL works fine in simulation but is no use for synthesis.
Thanks for the reply. RX is the receiver pin. I am implementing a protocol similar to CAN. The module is connected to wishbone bus. So CLK_I is wishbone clock.
The specification says I should synchronize to both edges of RX. I have changed the code little bit to compare the registered version of RX. Is this what you mean?
PROCESS (CLK_I)
BEGIN
tmp_RX <= RX;
IF (RX /= tmp_RX) THEN
ELSIF clk_cnt >2499 THEN
ELSE
END IF;
END IF;
END PROCESS;
thats much better, and should synthesise
