17246 Discussions
Synthesis of non-blocking statements
I'm wondering why the following two Verilog code snippets are synthesized in the same way.
Because of non-blocking statements, tools should give a warning in the first case.
# out is the default when a=0 always @(posedge clk) begin out <= 0 if(a) out <= in end
always @(posedge clk) begin if(a) out <= in else out <= 0 end
The two blocks of code are functionally equivalent. Verilog simulation and synthesis tools allow multiple NBA assignments to the same variable in the same process - the last write cancels the previous writes.
The writing style of the first block is convenient when a process contains many variable assignments and many branching statements. Each branch need only specify the NBA assignments that are different from the default.
--- Quote Start ---
--- Quote End ---
They don't however, and there's no reason why they should.
Due to the sequential code elaboration, the last assignment to a variable wins, all previous are ignored.
If you feel that explicite else statements improve code readability, you'll possibly use it in some cases though.
Ok, I found this clause in the Verilog 2001 spec, section "5.4.1 Determinism":
Nonblocking assignments shall be performed in the order the statements were executed inside begin-end block. Consider the following example:
initial begin a <= 0; a <= 1; end
When this block is executed, there will be two events added to the nonblocking assign update queue. The previous rule requires that they be entered on the queue in source order; this rule requires that they be taken from the queue and performed in source order as well. Hence, at the end of time step 1, the variable a will be assigned 0 and then 1.
