Understanding a counter
I want to understand this code. Can anyone tell help me, how does it work?
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use ieee.numeric_std.all;
use ieee.std_logic_arith.all;-- Uncomment the following library declaration if using-- arithmetic functions with Signed or Unsigned values--use
IEEE.NUMERIC_STD.ALL;-- Uncomment the following library declaration if instantiating-- any Xilinx primitives in this code.--library UNISIM;--use UNISIM.VComponents.all;
entity leds2_8 is
GENERIC (n: positive := 2**22);
Port ( clkin : in STD_LOGIC;
clkout : out STD_LOGIC;
leds : out STD_LOGIC_VECTOR (7 downto 0));
end leds2_8;
architecture Behavioral of leds2_8 is
begin
PROCESS (clkin)
VARIABLE count: INTEGER RANGE 0 to n;
variable counter : integer range 0 to 255;
BEGIN
IF(clkin'EVENT AND clkin='1') THEN
count :=count + 1;
IF(count=n/2) THEN
clkout <='1';
ELSIF (count=n) THEN
clkout <='0';
count :=0;
counter :=counter+1;
leds <=conv_std_logic_vector(counter,8);
END IF;
END IF;
END PROCESS;
end Behavioral;
you got two counters (count 0 ~ 2^22 and counter 0~255).
count outputs clkout at n/2 and n (not exactly right, should be n/2-1 and n-1 due to zero start value), it counts clocks
counter drives led output and is enabled when count is max
both counters can be free running as they are binary range(0~255,0~ 2^22-1) if you correct your range.
