does anyone have a .tcl-script for writing data via the System Console to Avalon-MM slaves that he/she want's to share? Cheers, PeterLink Copied
Here's a pretty basic script ...
# -----------------------------------------------------------------# jtag_cmds.tcl# # 11/9/2014 D. W. Hawkins (dwh@ovro.caltech.edu)# # SystemConsole commands.# # -----------------------------------------------------------------
# =================================================================# Master access# =================================================================# # -----------------------------------------------------------------# Open the JTAG master service# -----------------------------------------------------------------
# Open the first Avalon-MM master service
proc jtag_open {} {
global jtag
# Close any open service
if {} {
jtag_close
set master_paths
if { == 0} {
puts "Sorry, no master nodes found"
return
# Select the first master service
set jtag(master)
open_service master $jtag(master)
return
# -----------------------------------------------------------------# Close the JTAG master service# -----------------------------------------------------------------#
proc jtag_close {} {
global jtag
if {} {
close_service master $jtag(master)
unset jtag(master)
return
# -----------------------------------------------------------------# JTAG-to-Avalon-MM bridge read/write# -----------------------------------------------------------------#
proc jtag_read {addr} {
global jtag
if {!} {
jtag_open
# Read 32-bits
set data
return $data
proc jtag_write {addr data} {
global jtag
if {!} {
jtag_open
# Write 32-bits
master_write_32 $jtag(master) $addr
return
You can start System Console and then type tcl> source jtag_cmds.tcl and then you can type jtag_read <address> or jtag_write <address> <data> These are dead-simple procedures. They are *not* efficient for transferring large amounts of data. Check out the other master procedures for better options (or ask). Cheers, Dave
Hey Dave,
thanks heaps! That should get me started. Cheers, Peter
