17254 Discussions
Internal Error: Sub-system: OPT, File: /quartus/synth/opt/opt_ram.cpp, Line: 8319
I coded a dual port ram and while synthesising it, quartus 2 is showing the following message in a dialog:
this->m_read_a_during_write_b_behavior == CDB_RAM_READ_OLD_DATA
Stack Trace:
0x98C32 : opt_sea_of_mux + 0x289F2 (SYNTH_OPT)
0xB8226 : MLS_SCRIPT_MANAGER::~MLS_SCRIPT_MANAGER + 0xBAF6 (SYNTH_OPT)
0x97E4E : opt_sea_of_mux + 0x27C0E (SYNTH_OPT)
0x9701C : opt_sea_of_mux + 0x26DDC (SYNTH_OPT)
0x96CDE : opt_sea_of_mux + 0x26A9E (SYNTH_OPT)
End-trace
Quartus II Version 9.0 Build 235 06/17/2009 SJ Web Edition
Service Pack Installed: 2
please note that i ve connected all ports of the ram....
please help...
How did you connect it? from a megawizard file? in a BDF?
This is a Q2 crash - first of all try deleting the /db/ and /incremental_db/ folders and try recompiling. If that fails - can you try a newer version (9.0 is 5 years old).
