17254 Discussions
Testing C17 with JTAG Logic.
Hi guys. Im trying to do some tests in the circuit C17 based on JTAG tecnology. But I'm having some problems with the librarys. I have this code for Xilinx FGPAs:
library IEEE;use IEEE.std_logic_1164.all; library work; --use work.package.all; library selfext; use work.gates_pkg.all; use work.fflop_pkg.all;
but this doens't work on quartus II
Error (10481): VHDL Use Clause error at c17.vhdl(6): design library "work" does not contain primary unit "gates_pkg"
Error (10800): VHDL error at c17.vhdl(6): selected name in use clause is not an expanded name
Error (10481): VHDL Use Clause error at c17.vhdl(7): design library "work" does not contain primary unit "fflop_pkg"
Error (10800): VHDL error at c17.vhdl(7): selected name in use clause is not an expanded name
Error: Quartus II Analysis & Elaboration was unsuccessful. 4 errors, 0 warnings
How can I replace this librarys? Thank you for the help.
