17268 Discussions
[SystemVerilog] Passing "inout" thru verbatim
Hi all,
I have an Altera DE2-115 board and am working on interfacing with the asynchronous static RAM chip. I have gotten a simple test harness working, but only if it is the top-level entity. (See "asram_demo" below.)
However, obviously, I do not want to use this as a top level entity, as it's intended to evolve into a full SRAM controller. In fact, I have no idea how I could have multiple top-level entities anyway.
So, my next step was to have another actual top-level entity (called "DE2ASRAM") instantitate the "asram_demo" and pass the wires through verbatim before adding additional logic.
However, this leads to the following error:
Error (10663): Verilog HDL Port Connection error at DE2ASRAM.sv(17): output or inout port "SRAM_DQ" must be connected to a structural net expression
This does not in the slightest help me understand the problem or what to do about it. All I want to do is directly connect the incoming SRAM_DQ to the instantiated module's SRAM_DQ. But, it doesn't work.
I welcome any pointers or help here. How can I accomplish this?
Thanks!
module asram_demo( // DE2 keys, switches input logic SW, input logic KEY, output logic LEDR, output logic LEDG, // ASRAM Chip Lines output logic SRAM_ADDR, // Address inputs inout logic SRAM_DQ, // Data inputs/outputs output logic SRAM_CE_N, // Chip enable output logic SRAM_OE_N, // Output enable output logic SRAM_WE_N, // Write enable output logic SRAM_LB_N, // Lower byte control (I/O 0-7) output logic SRAM_UB_N // Upper byte control (I/O 8-15) ); logic enable_io_output; // Send data to SRAM? logic io_output; logic enable_ledr_output; // Display data on LEDR? logic ledr_output; // Remember: KEYs are HIGH (1) when NOT pressed, // so it really should be called KEY_n // We always leave the ASRAM chip enabled assign SRAM_CE_N = 1'b0; // We always do word-at-a-time access assign SRAM_LB_N = 1'b0; assign SRAM_UB_N = 1'b0; // Switches 0-9 : Data input (10) // Switches 12-17: Address selection (6) // Key 0: Output enable // Key 1: Write enable // Keys assign SRAM_OE_N = KEY; assign SRAM_WE_N = KEY; // Address assign SRAM_ADDR = {14'b0, SW}; // Data - this is the hard part. // We load the LEDR from the SRAM_DQ when we're reading, // but we load the SRAM_DQ from the switches when we're writing. // We don't output to LEDR unless we're reading. assign SRAM_DQ = enable_io_output ? io_output : 16'bZ; assign LEDR = enable_ledr_output ? ledr_output : 18'bZ; always_comb begin io_output = 16'b0; // Default output value (to avoid a latch) enable_io_output = 1'b0; // Don't enable output if unnecessary ledr_output = 18'bZ; // Wonder if this will work... enable_ledr_output = 1'b0; if (~KEY) begin // We're writing, so use I/O lines as output io_output = {6'b0, SW}; enable_io_output = 1'b1; end else if (~KEY) begin // We're reading and NOT writing, so use I/O lines as input ledr_output = {2'b0, SRAM_DQ}; enable_ledr_output = 1'b1; end end // always_comb endmodule
module DE2ASRAM( // DE2 keys, switches input logic SW, input logic KEY, output logic LEDR, output logic LEDG, // DE2 SRAM output logic SRAM_ADDR, inout logic SRAM_DQ, output logic SRAM_CE_N, output logic SRAM_OE_N, output logic SRAM_WE_N, output logic SRAM_LB_N, output logic SRAM_UB_N ); // The error is in the following line, regardless of // the way I enter the parameters. asram_demo demo(.*); endmodule
I believe the compiler is incorrectly classifying inout logic [15:0] SRAM_DQ, as a variable, not a net declaration. Try inout wire logic [15:0] SRAM_DQ, or inout [15:0] SRAM_DQ, . Verilog and SystemVerilog are both rife with implicit declaration madness.
Dave!!! You solved in 36 minutes (probably really more like 30 seconds) what I have been banging my head against for two days (probably 6-8 hours of real time).
Thank you so much.
For the record: both of your suggestions work in the top level module declaration:
inout SRAM_DQ, inout wire logic SRAM_DQ,
Needless to say I will have copious comments in my code describing this oddity.
Cheers!
