Hi~
I wrote a small program, use class. Inside the class, there is a task help me to do print and add 1 after 1 clk. However, program isn't run as I want, program will hold @(posedge clk) inside task. Could someone tell me what's going on?? TINGMING
timescale 1ns/1ps;
class sv_function;
local int i;
function new();
i = 0;
endfunction
function void print();
$display("Current i = %d",i);
endfunction
function void add_1();
i++;
endfunction
task op_print(input logic clk);
print();
@(posedge clk);
add_1();
endtask
endclass
module tb2();
parameter CLK_SPEED = 1;
logic clk;
logic reset;
event EVENT_FINISH_RESET;
event EVENT_FINISH_STIMULATE;
sv_function c = new;
// assignment area
// Design under test
always
begin
clk = 1'b0;
# CLK_SPEED;
clk = 1'b1;
# CLK_SPEED;
end
initial
begin
reset = 1'b0;
# CLK_SPEED;
reset = 1'b1;
# (CLK_SPEED*4);
reset = 1'b0;
-> EVENT_FINISH_RESET;
wait(EVENT_FINISH_STIMULATE);
$display("!!!!!SIMULATION FINISH!!!!!");
# 100000 $stop;
end
// testbench operation
initial
begin
wait(EVENT_FINISH_RESET);
c.op_print(clk);
c.op_print(clk);
c.op_print(clk);
->EVENT_FINISH_STIMULATE;
end
endmodule
