Hi. Previously my megafunction is not function correctly. I deleted the files and create a new one. I get an error when compiling. The error as below:
Error: Tcl error: can't unset "::quartus(qip_path)": no such element in array while executing "unset ::quartus(qip_path)" Info: set_global_assignment -name IP_TOOL_VERSION " › me" How to solve this error? thanksLink Copied
I have found the solution for it.
the solution is modify the path of the qip file in the .qsf file. thanks- Mark as New
That is right!!
Thank you for your menssage!
