17267 Discussions
Test a Verilog module via System Verilog
Petrov1
Trying to test a Verilog module via System Verilog. I'm analysing the RTL Simulation and I get the error: Error (10170): Verilog HDL syntax error at Test1.sv(29) near text: "program"; expecting a description.
I tried debugging it, but no results. It shows the error here after I instantiated the module I want to test.
interface valid_in1 (input clk);
logic din;
logic res;
logic out;
modport dut (input clk, din, res, output out);
modport tb (input out, output clk, din, res);
task monitor ();
while (1) begin
@(posedge clk);
if (din==1'b1) begin
$display ("@%0dns res %b out %b din %b clk %b",
$time, res, out, din, clk);
end
 end
endtask
endinterface: valid_in1
module valid (valid_in1.dut din);
valid_in dut (.clk(din.clk),   //the verilog module instantiation
              .din(din.din),
              .res(din.res),
              .out(din.out));
endmodule
program validprog (valid_in1.tb tin);
default clocking cb @(posedge tin.clk);
endclocking
initial begin
fork
tin.monitor();
join_none
tin.res <= 1;
tin.din <= 0;
##10 tin.res <= 0;
##1 tin.din <= 1;
##10 tin.din <= 0;
##5 $finish;
end
endprogram
module Test1 ();
logic clk= 0;
always #1 clk++;
valid_in1 cin (clk);
valid dut (cin);
validprog tb (cin);
endmodule
RichardTanSY_Altera
I checked and it seems that the 3.4 Programs construct whereby "The program building block is enclosed between the keywords program...endprogram"is currently Not supported in the Quartus synthesis tools.
To know more about the constructs supported. You may checkout the webpages below:
Verilog HDL Synthesis Support
SystemVerilog Synthesis Support
RichardTanSY_Altera
Petrov1
Worked as a charm in EDA Playground. Thank you
