17257 Discussions
The exe file generated after the high level synthesis does not work
gazel
I would like to simulate only the inference part of a MNIST three-layer fully coupled neural network with high level synthesis and modelsim.
The weights will be input from a txt file.
After the high level synthesis, an exe file is generated, but when I run it, nothing happens. What could be the cause of this?
I ran the file input program (fileinout.cpp) for practice and it worked fine.
The inference program works when I don't use hls.(same program)
ShengN_Intel
Hi gazel,
Regarding that HLS related problem you mentioned, may be you can migrate your post to Intel® High Level Design forum for better confirmation from there. The link of the forum as below:
https://community.intel.com/t5/Intel-High-Level-Design/bd-p/high-level-design
Sheng
