17246 Discussions
The lpm_add_sub and lpm_mult both have option to select input type as signed/unsigned
Contributeur émérite II
1 801 Visites
In case of 2's complement, addition and subtraction are the same. I am not sure about multiplication though. Therefore, what difference does it make if we select the input type as being signed or unsigned for the lpm_add_sub and lpm_mult? Does the way to carry out addition or subtraction actually change if we select the input type as being signed or unsigned?
0 Compliments
2 Réponses
1 067 Visites
--- Quote Start ---
--- Quote End ---
For +/- Yes it does with respect to carry bit for example [001] +[111] (+1-1) should be zero if signed but would be 8 [1000] if unsigned. Apart from that they are same.
The main advantage of 2's complement system is just that +/- become same as unsigned apart from above. mult is different
0 Compliments
1 067 Visites
--- Quote Start ---
--- Quote End ---
That's not how lpm_add_sub works. Carry bit generation is the same for signed and unsigned, please try. The only difference is in the generation of optional overflow bit.
Your example isn't quite right. In case of signed number you'll either add 3 bit number, then the there's no fourth result bit. Or you have four bit numbers, then you get [0001]+[1111] = [0000].
0 Compliments
Répondre
