17265 Discussions
The simulation of QUARTUSII is somthing wrong
i have a problem when i run the simulation tool of the Quartus II 9.2. The output doesn't change. Just before an hour or minute it works well. The output is changed follow i change the input. Delete the .vwf and creat the simulation file again the output still not change. No meter how i do like shutdown the computer or reinstall the Quartus II. The problem still can not solved. Does the Quartus II 9.2 hase some deadline to use?
which adition of quartus II you are using,becoz if it is subscription trial adition then i think u will get 30days trial but if it is webedition then u can use it but without hardware support.
In web edition,there is no deadline,u can use it forever.
