17264 Discussions
Custom Verilog module I/O missing :(
Hello!
I have a working design in Quartus II 9.1 that targets a Cyclone III. I want to add a custom component that I have written in Verilog. I have managed to add the component using SOPC Builder (which is the only way I have found to do it). Problem is that the component has no ports. It is just a brick with nothing to connect wires to.
Below is the Verilog code:
module Pulse2LogicLevel (RisingEdge, FallingEdge, LogicLevel);
// I/O Ports:
output LogicLevel;
input RisingEdge, FallingEdge;
// Internal Registers:
reg tmp, prevLL, prevRE, prevFE;
always @(RisingEdge or FallingEdge)
begin
tmp = ((RisingEdge == 1'b1) && (prevRE == 1'b0)) || prevLL;
prevLL = !((FallingEdge == 1'b1) && (prevFE == 1'b0)) && tmp;
prevRE = RisingEdge;
prevFE = FallingEdge;
end
assign LogicLevel = prevLL;
endmodule // Pulse2LogicLevel
As you can see, I have specified two input ports and one output port. I expected to see these as the I/O ports of the component I created in Quartus. Below is the procedure I used to add the component.
1) Double-click in Quartus II canvas to bring up the symbol insert page
2) Click "MegaWizard Plug-In Manager..." button
3) Select "Create a new custom megafunction variation" button on pop-up, then click "next"
4) Select "Altera SOPC Builder" megafunction, select "Verilog HDL" radio button, and provide name for output file "foo" in my project directory, then click "next".
5) In SOPC Builder, double-click "new component"
6) On "HDL Files" tab click "add..."
7) Browse to and open my source Verilog file, in this case "pulse2logiclevel.v".
8) On "Signals" tab I see all 3 of my I/O signals: RisingEdge, FallingEdge, and LogicLevel. By default they are set to the avalon_slave_0 interface type. These are not avalon signals, they are simply signals that I want to connect externally at the top level in Quartus. Therefore I CHANGE the interface type to "conduit_end" for all of them. I change the "signal type" for all of them to "export". In theory (according to documentation anyway) this should make these appear as ports on the SOPC component that will ultimately get instantiated in Quartus at the top level.
9) On the "Interfaces" tab I click "Remove interfaces with no signals". This eliminates all warnings and errors. The block diagram on this page shows my 3 signals marked as "export".
10) I click "finish". The component editor closes and a new component Pulse2LogicLevel appears in my "Library" on the left side of SOPC Builder.
11) Double-click Pulse2LogicLevel to add it to my system.
12) Click "generate" to generate the system. It generates successfully with no errors or warnings.
13) Save and Exit SOPC Builder, bringing me back to the symbol insertion popup.
14) The "foo" symbol is displayed in the symbol insertion window. It has no ports.
15) I click "ok" and place an instance of the component at the top level of my Quartus design. As expected, the instance has no ports.
I am either doing something wrong or am leaving out a step or 2. Does anyone see what I am doing wrong?
Thanks for any help you can offer!
LH
Maybe you are making a bit of confusion. I think you want to add your component in the top level of Quartus project, but you are trying to add it as a new SOPC builder component, which it is not (infact it has neither a Avalon, nor irq nor any other sopc supported interface).
What you mean is probably this: open your Verilog file, open File menu and select Create/update, then "Create Symbol Files for current file"; now you can add the Pulse2LogicLevel block in your top level schematic, or instantiate it in the top level HDL.
Cris
Thanks Chris. I was able to make the component at the top level using your instructions, and it even has i/o ports! I was using an external editor and did not realize that I needed to use the internal editor to convert Verilog into a placeable component. As you can tell, I am still a Quartus n00b. :)
I have a large SOPC block in my design that contains a NIOS II, memory, and many other components that work great. I had originally tried incorporating my custom Verilog into that system, but again my conduits did not result in additional i/o ports on the SOPC "brick" back in my Quartus schematic.
Am I misunderstanding the meaning of conduits? I'm sure this will come up in the future.
Thanks again for you quick, correct, and most helpful response!
LH
--- Quote Start ---
--- Quote End ---
In sopc builder component editor, in the "Signals" tab, you must define the signal type as "export": all these signals will appear in the sopc "brick" as I/O port.
As I told you before, I assume your HDL implements a sopc compatible interface on the other side (i.e. Avalon MM slave), otherwise the component can't have connections with the rest of sopc system and this makes little sense.
If you simply need to integrate sopc system and your custom block into a single brick component, you'd better write a HDL wrapper which instantiates both and expose the signals to the top level.
