17255 Discussions
TimeQuest Issue with wrong launch clock & wrong latch edge
In my VHDL code, I use rising_edge for shift registers to latch data.
But TimeQuest report timing of these shift registers using falling edge of clock.
What's wrong?
pls see the detailed VHDL code below:
LIBRARY IEEE; USE IEEE.std_logic_1164.ALL; USE IEEE.std_logic_unsigned.ALL; USE IEEE.std_logic_arith.ALL; entity FreqMeasure_ADReader is port ( IN_AD_SCLK : in std_logic; IN_TARGET_SIGNAL : in std_logic; IN_AD_DATA : in std_logic; OUT_AD_SCLK : out std_logic; OUT_AD_VALUE : out integer ); constant c_AD_RESOLUTION : integer :=16; end entity; architecture register_ad_sclk of FreqMeasure_ADReader is component SynSignalGenerator_CrossingClockDomain is port ( IN_CLK : in std_logic; IN_STROBE : in std_logic; OUT_SYN_SIGNAL : inout std_logic ); end component; signal s_ad_sdata_shift_reg : std_logic_vector(c_AD_RESOLUTION-1 downto 0); signal s_ad_sclk_enable :std_logic; signal s_ad_sclk :std_logic; signal s_counter :integer range c_AD_RESOLUTION*2 downto 0; signal s_target_signal : std_logic; signal s_counter_synclear : std_logic; begin s_target_signal <= NOT IN_TARGET_SIGNAL; counter_synclear_gen: SynSignalGenerator_CrossingClockDomain PORT MAP(IN_AD_SCLK, s_target_signal, s_counter_synclear); sclk_en_gen: process(IN_AD_SCLK, s_counter_synclear) begin if(s_counter_synclear = '1') then s_counter <= 0; elsif(rising_edge(IN_AD_SCLK)) then if(s_counter = 1) then s_ad_sclk_enable <= '0'; s_counter <= s_counter + 1; elsif(s_counter < c_AD_RESOLUTION * 2) then s_ad_sclk_enable <= '0'; s_counter <= s_counter + 1; else s_ad_sclk_enable <= '1'; end if; end if; end process; ad_sclk_gen: process(IN_AD_SCLK, s_ad_sclk_enable) begin if(s_ad_sclk_enable = '0') then if(rising_edge(IN_AD_SCLK)) then s_ad_sclk <= NOT s_ad_sclk; end if; else s_ad_sclk <= '1'; end if; end process; OUT_AD_SCLK <= s_ad_sclk; shift_reg_0: process(s_ad_sclk) begin if(rising_edge(s_ad_sclk)) then s_ad_sdata_shift_reg(0) <= IN_AD_DATA; end if; end process; shift_reg_gen: for i in 1 to s_ad_sdata_shift_reg'high generate process(s_ad_sclk) begin if(rising_edge(s_ad_sclk)) then s_ad_sdata_shift_reg(i) <= s_ad_sdata_shift_reg(i-1); end if; end process; end generate; OUT_AD_VALUE <= CONV_INTEGER(s_ad_sdata_shift_reg); end register_ad_sclk;
Pls see the following TimeQuest screen shot pic:
http://blogimg.chinaunix.net/blog/upfile2/080124210233.jpg
Another question:
I create AD_SCLK for *|FreqMeasure_ADReader:*|s_ad_sclk, pls see below
create_generated_clock -name AD_SCLK -source FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk2 -divide_by 2
And TimeQuest report timing of *|FreqMeasure_ADReader:*|s_ad_sclk with wrong launch clock, the launch clock should be FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk2.
Pls note that: *|FreqMeasure_ADReader:*|s_ad_sclk is a toggle register launch & latch by FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk2, which make TimeQuest confused.
How can I correct TimeQuest to report correct timing in this case?
Pls also see the following screen shot pic:
http://blogimg.chinaunix.net/blog/upfile2/080124210633.jpg
I have look into technology post-fitting view, and found that the shift register I mentioned before was driven by falling edge of pll|clk2. So the TimeQuest report is right.
But I VHDL code is using
--- Quote Start ---
end if;
--- Quote End ---
And What I want is rising_edge, what I can do?
Also, pls don't forget my senond question described above.
Thanks!
