In my VHDL code, I use rising_edge for shift registers to latch data.
But TimeQuest report timing of these shift registers using falling edge of clock. What's wrong? pls see the detailed VHDL code below:LIBRARY IEEE;
USE IEEE.std_logic_1164.ALL;
USE IEEE.std_logic_unsigned.ALL;
USE IEEE.std_logic_arith.ALL;
entity FreqMeasure_ADReader is
port
IN_AD_SCLK : in std_logic;
IN_TARGET_SIGNAL : in std_logic;
IN_AD_DATA : in std_logic;
OUT_AD_SCLK : out std_logic;
OUT_AD_VALUE : out integer
constant c_AD_RESOLUTION : integer :=16;
end entity;
architecture register_ad_sclk of FreqMeasure_ADReader is
component SynSignalGenerator_CrossingClockDomain is
port
IN_CLK : in std_logic;
IN_STROBE : in std_logic;
OUT_SYN_SIGNAL : inout std_logic
end component;
signal s_ad_sdata_shift_reg : std_logic_vector(c_AD_RESOLUTION-1 downto 0);
signal s_ad_sclk_enable :std_logic;
signal s_ad_sclk :std_logic;
signal s_counter :integer range c_AD_RESOLUTION*2 downto 0;
signal s_target_signal : std_logic;
signal s_counter_synclear : std_logic;
begin
s_target_signal <= NOT IN_TARGET_SIGNAL;
counter_synclear_gen: SynSignalGenerator_CrossingClockDomain PORT MAP(IN_AD_SCLK, s_target_signal, s_counter_synclear);
sclk_en_gen: process(IN_AD_SCLK, s_counter_synclear)
begin
if(s_counter_synclear = '1') then
s_counter <= 0;
elsif(rising_edge(IN_AD_SCLK)) then
if(s_counter = 1) then
s_ad_sclk_enable <= '0';
s_counter <= s_counter + 1;
elsif(s_counter < c_AD_RESOLUTION * 2) then
else
s_ad_sclk_enable <= '1';
end if;
end if;
end process;
ad_sclk_gen: process(IN_AD_SCLK, s_ad_sclk_enable)
begin
if(s_ad_sclk_enable = '0') then
s_ad_sclk <= NOT s_ad_sclk;
end if;
else
s_ad_sclk <= '1';
end if;
end process;
OUT_AD_SCLK <= s_ad_sclk;
shift_reg_0: process(s_ad_sclk)
begin
if(rising_edge(s_ad_sclk)) then
s_ad_sdata_shift_reg(0) <= IN_AD_DATA;
end if;
end process;
shift_reg_gen: for i in 1 to s_ad_sdata_shift_reg'high generate
process(s_ad_sclk)
begin
s_ad_sdata_shift_reg(i) <= s_ad_sdata_shift_reg(i-1);
end if; end process;
end generate;
OUT_AD_VALUE <= CONV_INTEGER(s_ad_sdata_shift_reg);
end register_ad_sclk;
Pls see the following TimeQuest screen shot pic: http://blogimg.chinaunix.net/blog/upfile2/080124210233.jpg Another question: I create AD_SCLK for *|FreqMeasure_ADReader:*|s_ad_sclk, pls see below create_generated_clock -name AD_SCLK -source FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk2 -divide_by 2
And TimeQuest report timing of *|FreqMeasure_ADReader:*|s_ad_sclk with wrong launch clock, the launch clock should be FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk2. Pls note that: *|FreqMeasure_ADReader:*|s_ad_sclk is a toggle register launch & latch by FreqMeasure_NiosII:inst|pll:the_pll|altpllpll:the_pll|altpll:altpll_component|_clk2, which make TimeQuest confused. How can I correct TimeQuest to report correct timing in this case? Pls also see the following screen shot pic: http://blogimg.chinaunix.net/blog/upfile2/080124210633.jpg
I have look into technology post-fitting view, and found that the shift register I mentioned before was driven by falling edge of pll|clk2. So the TimeQuest report is right.
But I VHDL code is using --- Quote Start --- if(rising_edge(s_ad_sclk)) then s_ad_sdata_shift_reg(i) <= s_ad_sdata_shift_reg(i-1); end if; --- Quote End --- And What I want is rising_edge, what I can do? Also, pls don't forget my senond question described above. Thanks!
