17268 Discussions
TimeQuest, issues with negative edge registers and inverted clocks
When using negative edge registers or inverted clocks TimeQuest is incorrectly analyzing the timing.
module TEST(input clock_50, input in, output reg out); reg tmp; always @(posedge clock_50) tmp = in; always @(negedge clock_50) out = tmp; endmodule
from node: tmp, to node: out~reg0
setup: slack: 0.350, relationship: 0.500
hold: slack: 19.232, relationship: -19.500
With a 50Mhz clock the relationship should be 10.000, I don't understand why its giving the wrong value.
The "-invert" option of create_generated_clock also gives the wrong value, however using "-phase 180" results in the expected relationship of 10.000, (half the clock period).
Maybe this is a bug but I have failed to find any mention of this issue.
Can you post screenshot of the waveforms from TimeQuest worst-case path report?
