TimeQuest puzzle
I am trying to learn TimeQuest and it's not going very quickly I'm afraid.
I have a little MAXII example I am trying to analyze with TimeQuest that is giving me fits. In this example, I am circulating data between an internal
and an external register using a generated external clock which is only output some of the time. In this simplified example, only every other clock is output to EXT_CLK, but more generally, I need to control EXT_CLK with more complex logic. I am using Quartus II 9.1.
Here's the Verilog:
module TimeQuestExample
input CLK,
output EXT_CLK,
input DATA_IN,
output DATA_OUT
reg data;
assign DATA_OUT = data;
reg toggle;
assign EXT_CLK = !CLK && toggle;
always @(posedge CLK) begin
toggle <= !toggle;
data <= DATA_IN;
end
endmodule
And here is the SDC file I am using:
create_clock -period 30 [get_ports CLK]
create_generated_clock -source [get_pins {EXT_CLK~0|combout}]
-master_clock [get_clocks {CLK}] [get_ports EXT_CLK]
set_input_delay -clock CLK 0 [get_ports {CLK}]
set_input_delay -clock EXT_CLK -clock_fall 8 [get_ports {DATA_IN}]
set_output_delay -clock EXT_CLK 7 [get_ports {DATA_OUT}]
When I run the timing analyzer, I get lots of unconstrained paths with
report_ucp. However, if I add the following constraint, all the issues just
go away.
set_output_delay -clock EXT_CLK 0 [get_ports {EXT_CLK}]
Can anybody help me understand why this works (if correct), or what would
be a better way to get the design fully constrained.
henderbc
--- Quote Start ---
Here's the Verilog:
input CLK,
output EXT_CLK,
input DATA_IN,
output DATA_OUT
reg data;
reg toggle;
toggle <= !toggle;
data <= DATA_IN;
end
endmodule
go away.
henderbc
--- Quote End ---
without timing constraint Timequest did not check the timing of e.g. outputs. In your case you don't have a constraint for the output "EXT_CLK". When you look back from the pin into your design you found two paths ( EX_CLK -> CLK, EXT_CLK -> "toggle") which therefore are not constrainted. You also need the constraint in order to ensure that the DATA_OUT is correct latch with you EXT_CLK.
Kind regards
GPK
Hi GPK - thanks for you answer. What is still puzzling me is the meaning of the constraint:
If I understand what set_output_delay is supposed to do, I would think this means:
"EXT_CLK will take a while to get to my external device so we better delay EXT_CLK by that much to make sure EXT_CLK is correctly latched at the external device by EXT_CLK"
This sounds like nonsense to me. What am I missing?
--- Quote Start ---
--- Quote End ---
a good explanation could be found in the Application Note AN433 helps:
http://www.altera.com/literature/an/an433.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=an433
Kind regards
GPK
Hi GPK,
That helps a lot. I'm thinking the constraint I had was nonsense. I changed it to:
set_output_delay -clock CLK 1.23 [get_ports {EXT_CLK}]
which also makes the unconstrained ports and paths problems go away.
Is the above constraint now correct?
If so, what does it mean in English, and how should I calculate the delay value? (I just stuck in 1.23)
If not, how should it be written?
Thanks for your patience
--- Quote Start ---
Hi GPK,
--- Quote End ---
the value depends on the requirements of the receiving device. Are the data latched in with the pos- or negedge ? What is the required setup time ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
Hi GPK,
I'm not really too concerned about the value - I don't understand the meaning. Here's a picture that might simplify this discussion:
http://photosbybruce.smugmug.com/photos/749483837_kenbm-m.jpg
The constraints I entered for Quartus were:
create_generated_clock -source [get_pins {EXT_CLK~0|combout}] \
set_output_delay -clock EXT_CLK 2 [get_ports {DATA_OUT}]
These constraints give my intent for the design. But when I analyze the design with TimeQuest and output the report_ucp,
I get the following:
; Unconstrained Paths ;
; Unconstrained Paths Summary ;
; Property ; Setup ; Hold ;
; Illegal Clocks ; 0 ; 0 ;
; Unconstrained Clocks ; 0 ; 0 ;
; Unconstrained Input Ports ; 1 ; 1 ;
; Unconstrained Input Port Paths ; 1 ; 1 ;
; Unconstrained Output Ports ; 1 ; 1 ;
; Unconstrained Output Port Paths ; 2 ; 2 ;
; Clock Status Summary ;
; Target ; Clock ; Type ; Status ;
; CLK ; CLK ; Base ; Constrained ;
; EXT_CLK ; EXT_CLK ; Generated ; Constrained ;
; Setup Analysis ;
; Output Port ; Comment ;
; EXT_CLK ; No output delay, min/max delays, false-path exceptions, or max skew assignments found. This port has clock assignment. ;
; From ; To ; To Clocks ;
; CLK ; EXT_CLK ; CLK ;
; From ; To ; From Clocks ;
; CLK ; EXT_CLK ; ;
; toggle ; EXT_CLK ; CLK ;
; Hold Analysis ;
; CLK ; EXT_CLK ; ;
Am I missing an important constraint? What do I need to change to make these unconstrained ports and paths go away?
Bruce
--- Quote Start ---
Hi GPK,
; Setup Analysis ;
; CLK ; EXT_CLK ; ;
; Hold Analysis ;
; CLK ; EXT_CLK ; ;
Bruce
--- Quote End ---
Hi Bruce
I have a project attached. Maybe it helps to understand how to solve your problem.
You have to define an output constraint for your EXT_CLK output.
Kind regards
GPK
