Hi everyone,
I got problems when i was using Timequest. My clock name is CLK, but quartus told my that "Warning (332060): Node: CLK~reg0 was determined to be a clock but was found without an associated clock assignment." Is there anybody can help me ? Thank you very much!Link Copied
I assume you have a port called CLK and somehow you are inferring a register, so it gets the name CLK~reg0. That register is then used as the clock of another register. (I'm making a lot of assumptions, so may be wrong).
So first, do you expect CLK~reg0 to exist as a register. Look for it in your RTL or RTL Viewer and see why it's occurring. If it's not supposed to be there, change the code. If it's correct, see how it's used as a clock. A quick thing I would do in TimeQuest is: create_clock -name test_clk -period 10.0 {CLK~reg0} ;# This puts a clock constraint on it report_timing -setup -npaths 100 -detail full_path -to_clock test_clk -panel_name {-> CLK~reg0} ;# This reports timing to this clock, so all destinations use this as a clock. Now you know what you have, and need to decide how you want to constrian it(e.g. you may want to use create_generated_clock instead of create_clock, I don't know). My guess is that you don't want this register to exist, or to be used as a clock, and it's an RTL change that will fix it.- Mark as New
Thank you!I assigned this port to a register in order to divide frequency. The code is
always@(posedge CLK1)
begin
if(RST1)
begin
count <= 0;
CLK <= 0;
end
else
begin
if(count == ((N/2)-1))
begin
CLK <= !CLK;
count <= 6'b0;
end
else
count <= count + 6'b1;
end
end
By the way, could you tell me what will you do if you want to divide 50M frequency into 0.5M?
Assuming CLK1 is an input port and you're dividing by 100:
create_clock -period 20.0 -name CLK1 [get_ports CLK1] create_generated_clock -source CLK1 -divide_by 100 [get_keepers CLK] Now, I'm guessing CLK is a reg and an output port. Quartus synthesis will name the output port CLK and the internal reg something like CLK~reg. I recommend not name a register and port the same thing, e.g. the divide down register could be CLK_REG and the output CLK: assign CLK = CLK_REG; If you do that, assign the generated clock to [get_keepers CLK_REG]- Mark as New
Thank you very much! Sorry to reply you sooo late...
Topic Options
