17267 Discussions
Timequest for asynchronous design
VFres
​Hello,
Is it possible to use timequest to have information about delays inside an asynchronous design?
I would like to know the time between 2 nodes that are not linked by any clock. I have just combinatorial functions.
But if I try to use the report_path command:
report_path -from [x] -to [y]
I just receive:
Report Path: No paths were found
Thanks for help
sstrell
You don't mention what x and y are (ports, pins?) but the main command to use is report_timing. It should look something like this:
report_timing -setup -from [get_[pins/ports] x] -to [get_[pins/ports] y]
#iwork4intel
KhaiChein_Y_Intel
Does the design contain any registers? You can see the delay for a combinational logic between registers by reporting the timing between the registers. The Timing Analyzer recognizes and analyzes the following timing paths only.
  • Edge paths—connections from ports-to-pins, from pins-to-pins, and from pins-to-ports.
  • Clock paths—connections from device ports or internally generated clock pins to the clock pin of a register.
  • Data paths—connections from a port or the data output pin of a sequential element to a port or the data input pin of another sequential element.
  • Asynchronous paths—connections from a port or asynchronous pins of another sequential element such as an asynchronous reset or asynchronous clear.
KhaiY
VFres
​Hi,
Thank you for your answer.
So if I don't have any register there is no way to know delays between luts?
report_timing gives the same:
"Report Timing: No setup paths were found"
Best regards
skyjuice
report_path should be able to do what you want. Just make sure you use the correct filter as what sstrell mentioned
