17268 Discussions
Timequest unconstrained paths clock summary
Hello and good morning from Germany.
i have got a problem with the timequest Analyser tool. In the following code you can see my first test of the RS232 Interface. It works but if i start the timequest tool, the timequest tool said: RS232_CONTROL:RS232CNT|RS232_RX:RS232RX|l_mstate.IDLE~1 is a clock. But it isn't a clock. Whats happen? could you please help me?
library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; entity RS232_RX is generic( CLK_MUL: natural := 6; BITS: natural := 8; STOPBIT: natural range 0 to 1 := 0); port( RESET: in bit; NDATA: in bit; -- new data READY: out bit; -- ready for new data BCLK: in bit; databit: in bit_vector(BITS-1 downto 0); DO: out bit); end RS232_RX; architecture STRUCT of RS232_RX is type state is (IDLE, START, SEND, STOP); signal l_databit: bit_vector(BITS-1 downto 0); signal iclk: bit := '0'; signal l_mstate: state; signal l_obit: bit := '1'; --idle bit signal l_ready: bit := '0'; begin P1: process(BCLK,RESET,databit,NDATA,l_ready) variable v_counter: integer range 0 to CLK_MUL := 0; --integer variable v_bcnt: integer range 0 to BITS-1 := 0; --integer rang 0 bis BITS; variable vcnt_stbbit: integer range 0 to 1 := STOPBIT; --anzahl der stopbits begin if RESET='1' then l_mstate <= IDLE; --set the machine to start. v_counter := 0; -- reset v_counter l_ready <= '1'; --set ready to not ready for new data i am in the process. elsif NDATA = '1' and l_ready = '1' then --new data? l_databit <= databit; --nur bei reset zuweisen l_mstate <= START; l_ready <= '0'; elsif BCLK'event and BCLK='0' then if v_counter=0 then v_counter := CLK_MUL-1; case l_mstate is when IDLE => null; l_mstate <= IDLE; --set the machine to start. when START => l_obit <= '0'; l_mstate <= SEND; v_bcnt := BITS-1; vcnt_stbbit := STOPBIT; when SEND => l_obit <= l_databit(0); l_databit <= '0' & l_databit(BITS-1 downto 1); if v_bcnt = 0 then l_mstate <= STOP; else v_bcnt := v_bcnt -1; end if; when STOP => l_obit <= '1'; if vcnt_stbbit = 0 then l_mstate <= IDLE; l_ready <= '1'; --ready for new data else vcnt_stbbit := vcnt_stbbit-1; end if; end case; else v_counter := v_counter - 1; end if; end if; end process P1; PO: process(l_obit,l_ready) begin READY <= l_ready; DO <= l_obit; end process PO; end STRUCT;
PS.: In the attachment is a screen shoot of the timequest analyzer.
This seems a very odd setup. Why are NDATA and l_ready used to asynchronously set the state machine and data bit? thats not very timing safe. They should be part of the logic that flips the design out of the IDLE state. This is the only reason I can think of it's chosen to make the idle state as some form of clock in your async logic.
