17255 Discussions
Timing analysis for a different device without recompiling
YOGon
I have a desing compiled for an EP3C5  but I need to deploy it on an EP3C10 without recompiling it. (The package is the same for both devices).
Is there a way in Quartus to analyze the timing behaviour in the EP3C10 without recompiling the design for this device?
sstrell
The package may be the same, but the internals are different.  You would need to recompile.
You can simplify this in a few ways: add a new revision of your Quartus project with the different device set as the target or enable the second device as a migration device.
SyafieqS
Yolanda,
Yes true, it is the same package, but you still need to recompile in order to get clean timing (assuming timing is closed)
SyafieqS
Yolanda,
May I know if there is any update?
YOGon
Your answer is  clear: I have to recompile. Thank you.
