17253 Discussions
Timing constraints about tpd
Hello All,
I want to introduce about 10 ns delay between the outputs oe_o and dir_o,oe_o follow the dir_o.
Example:
module delay_10ns(oe_i,dir_i,oe_o,dir_o);
input oe_i,dir_i;
output oe_o,dir_o;
//inout
assign oe_o = ~ oe_i;
assign dir_o = ~ dir_i;
endmodule
QII's version is 8.1,when I use the following constraints:
set_instance_assignment -name TPD_REQUIREMENT "10 ns" -from dir_i -to dir_o
set_instance_assignment -name MINIMUM_TPD_REQUIREMENT "20 ns"-from oe_i -to oe_o
It works.but when I disable the TPD_REQUIREMNT constraint between dir_i and dir_o,the oe's MINIMUM_TPD_REQUIREMENT constraint does't work.
why,anyone can tell me? Thanks in advance!
