I'm using a LAN9211 ethernet controller with a Cyclone III fpga. The ethernet controller is attatched to a Nios II processor through a Generic Tri-State Controller using Qsys. My problem is, that sometimes everything works great, but after changing something completely unrelated to the ethernet controller and recompiling my project, I suddenly get currupted data on that interface. So my conclution is, that there are timing problems with ethernet controller :(. I've consulted the datasheet of the LAN9211 many times, trying to find the best timing settings for the Generic Tri-State Controller, but there are some timings I just can't map to the Qsys settings: My current settings are: > System clock: 90MHz Read wait time: 32ns Write wait time: 32ns Setup time: 0ns Hold time: 0ns Max. pending read transactions: 3 Turnaround time: 2 Read latency: 2 Chipselect through read latency: not checked My problems are: 1. According to the LAN9211's datasheet, chipselect must be deasserted for at least 13ns between two successive read or write cycles. Writing 32bit data words from NIOS, but having a 16bit interface, I see that cs is only deasserted one clock cycle (11.1ns) inbetween writing lower and higher bytes. How can I fullfill the deassertion time requirement without having to use 16bit Read/Writes or writing my own tri-state controller? 2. Setup and hold times are both specified with 0ns. But this does not ensure, that - depending on the fitter results and the board skew - these timings are not negative in respect to each other (i.e. data beeing invalid before write signal is deasserted). Do I have to take this into account by setting the setup and hold times to someting like 5ns (loosing 2 clock cycles) or can this be handled setting timing constraints with TimeQuest? => How would this constraint have to look like? Please let me know about your experience with specifying timings for asynchronous interfaces, any suggestions are welcome :). Best Regards SimonLink Copied
Any help please?
