Total Registers Used = 0
Dear all,
I have a strange problem with synthesising my design. the problem is when I have a top level that connects my board signals to my design logic I get every thing synthesised away.
I'm using Verilog-2001 HDL
My design hierarchy is as follow:
  • Board Top Level
  • My Design To Level Instance
  • My design Modules Instances
When I synthesise my design as top level every thing is synthesised just fine, but when I add one more level on top of that I got nothing, every thing is synthesised away !!
Please give me a clarification to this strange problem.
Thank you.
This happens, if either no top entity outputs are connected to the design, or the outputs are all constant, e.g. because you didn't connect clock or reset inputs.
Of course I did connected my DE2_70 CLOCK_50 into my design. Also, I connected KEY[0] as a reset signal. However, I'm still having the problem
--- Quote Start ---
--- Quote End ---
O.K., but something is obviously missing, Quartus is following an exact method to determine which parts of the design can be removed.
Yep you were right, I was not having any output to the board. Once I added a dummy output every thing got synthesized jut fine.
Thank you for your clearification.
