17254 Discussions
Total noob question on programming jic into de0-nano
I'm a complete and utter n00b to FPGA programming and the Quartus suite in general.
I thought I'd try getting my hands dirty on some of the basics; sending existing programs to the device. And, hey, the "System CD" comes with some nice examples!
I'm running 13.1 on Ubuntu 12.04LTS. The software installed, no problem. A bit of searching and I configured jtagd, and I can see the device properly using jtagconfig. So far so good!
I can also send an SOF to the device and it runs from RAM nicely:
/altera/13.0sp1/quartus/bin/quartus_pgm -m jtag -o 'p;DE0_NANO_G_Sensor.sof' /altera/13.0sp1/quartus/bin/quartus_cpf -c -d EPCS16 -s EP4CE22 DE0_NANO_G_Sensor.sof foo.jic quartus_pgm -m jtag -o 'bpvi;foo.jic'
And now it all goes wrong...
Info (213045): Using programming cable "USB-Blaster " Info (213011): Using programming file output_file.jic with checksum 0x151558FA for device EP4CE22@1 Info (209060): Started Programmer operation at Tue Sep 10 23:42:21 2013 Info (209016): Configuring device index 1 Info (209017): Device 1 contains JTAG ID code 0x020F30DD Info (209007): Configuration succeeded -- 1 device(s) configured Info (209018): Device 1 silicon ID is 0x16 Info (209044): Erasing ASP configuration device(s) Info (209019): Blank-checking device(s) Error (209026): Blank-Check failed on device 1 Error (209012): Operation failed
If I don't specify "b" then I can sometimes (but not 100%) program it.
Similarly with the DE0_NANO_default/output_file.jic file that came on the CD,
I also get the blank error if I try to use the GUI "programmer" interface.
Am I doing something stupid? Any guidance much appreciated.
Thanks!
