Hi bros, this is my VHDL code to implement an "ARCTAN" function:
-- This is my code -- LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; USE IEEE.MATH_REAL.ALL; USE IEEE.STD_LOGIC_ARITH.ALL; USE IEEE.numeric_std.ALL; USE ieee.std_logic_signed; USE ieee.std_logic_unsigned; ENTITY arctan IS GENERIC (NUMBER_BIT: INTEGER:=16); PORT ( clk: IN STD_LOGIC; reset: IN STD_LOGIC; data_inI: IN STD_LOGIC_VECTOR(NUMBER_BIT-1 DOWNTO 0); data_inQ: IN STD_LOGIC_VECTOR(NUMBER_BIT-1 DOWNTO 0); arc_out: OUT STD_LOGIC_VECTOR (5 DOWNTO 0) ); END arctan; ARCHITECTURE bhv OF arctan IS BEGIN PROCESS(clk,reset) VARIABLE real_val1: REAL :=0.0; VARIABLE real_val2: REAL :=0.0; VARIABLE temp : REAL := 0.0; BEGIN IF (reset='0') THEN arc_out<=(OTHERS=>'0'); ELSE IF(clk'EVENT AND clk='1') THEN ---convert STD_LOGIC type to REAL type---------- real_val1:= CONV_INTEGER(SIGNED(data_inI))**0.00003052; --1/(2^15)=1/32768=0.00003052 real_val2:= CONV_INTEGER(SIGNED(data_inQ))**0.00003052; -------------------------------------------------- temp:=ARCTAN(real_val1,real_val2); arc_out<= CONV_STD_LOGIC_VECTOR(CONV_SIGNED(INTEGER(temp*32768.0),6)); END IF; END IF; END PROCESS; END bhv; -- End of my code -- And when I tried to compile it with Modelsim-Altera Starter Edition 10.0, I got a message as shown below: Can you help me to solve this issue? Thank you so much.Link Copied
You are including too many libraries. Those two are in direct conflict:USE ieee.std_logic_signed;
The first one says you will want to do arithmetic directly on std_logic_vectors, using them as signed values, while the other one says you will use them as unsigned values. But both are non standard, so you should better remove them entirely.
define a SIGNED type, so you should keep only one of them. I recommend to keep ieee.numeric_std.all, which is the only standard one. So as a result, use only those libraries in your code:USE IEEE.STD_LOGIC_1164.ALL;
And then fix the remaining errors that you get, mostly with the CONV functions that aren't defined any more. You can use the SIGNED type instead, and use the to_integer and to_signed functions for conversions. Are you writing this just for simulating, or also to synthesize and put in an FPGA? The functions from MATH_REAL and the real types can't be synthesized.
