17263 Discussions
Transceiver Toolkit disabled menu on Quartus Web Edition
Hi guys,
Is transceiver toolkit available on Quartus Web Edition?
I tried 14 and 15 versions and Transceiver Toolkit option under Tools/System Debug Tools/ menu is always disabled. I have a Altera Cyclone V GX Terasic board and even with example designs I can't start this toolkit. There something special to be done for enable it? :-/
thanks
transceiver toolkit is not available in the Quartus II web edition. You may refer to https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/po/ss_quartussevswe.pdf for further details.
Thank you for your help. I checked about quartus support before but as I saw my Cyclone V GX was supported I assumed Quartus will provide all tools for my studies. Sorry for that.
I will download 30-days limit version Quartus althought I know will not enough time to learn all I want. Thank's again.
Thank you.
I installed 30-day evaluation Quartus but trasceiver toolkit menu is still disabled.
I can start it via system console manually but seems do not recognize any channel from my cyclone x gx device.
I appreciate any tip, thank you. I'm new on this world ;-)
Just wonder if you are using the transceiver toolkit design example to work with your toolkit? From my experience, it is recommended to use the design example from https://www.altera.com/support/support-resources/design-examples/design-software/on-chip-debugging.html
Yes, I'm using Terasic design example. I will try to use this one, thank you!
