Hi guys,
Is transceiver toolkit available on Quartus Web Edition? I tried 14 and 15 versions and Transceiver Toolkit option under Tools/System Debug Tools/ menu is always disabled. I have a Altera Cyclone V GX Terasic board and even with example designs I can't start this toolkit. There something special to be done for enable it? :-/ thanksLink Copied
transceiver toolkit is not available in the Quartus II web edition. You may refer to https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/po/ss_quartussevswe.pdf for further details.- Mark as New
Thank you for your help. I checked about quartus support before but as I saw my Cyclone V GX was supported I assumed Quartus will provide all tools for my studies. Sorry for that.
I will download 30-days limit version Quartus althought I know will not enough time to learn all I want. Thank's again.- Mark as New
Thank you.
I installed 30-day evaluation Quartus but trasceiver toolkit menu is still disabled. I can start it via system console manually but seems do not recognize any channel from my cyclone x gx device. I appreciate any tip, thank you. I'm new on this world ;-)- Mark as New
Just wonder if you are using the transceiver toolkit design example to work with your toolkit? From my experience, it is recommended to use the design example from https://www.altera.com/support/support-resources/design-examples/design-software/on-chip-debugging.html
Yes, I'm using Terasic design example. I will try to use this one, thank you!
