17255 Discussions
Tri-state fanout converted to OR gate
I'm writing Verilog code for an I2C expander with bidirectional 16-bit output.
If I need to read the status of the pins into a register, which means I the tr-state output pins are connected to a reg variable (along with the output pins), I get the below mentioned warning from Quartus.
Warning: Converted the fan-out from the tri-state buffer "i2c_expander_v2:i2c1|register_logic_v2:reg1|bidir_io:gpio15|io" to the node "i2c_expander_v2:i2c1|register_logic_v2:reg1|input_reg2[7]" into an OR gate
This occurs for all the 16-bits.
The device is Max II CPLD.
Any help how I go about this?
Ram
Sounds like your code doesn't utilize the pins bidirectionally.
Make sure to follow the coding guideline on page 54 of this document: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf
My bidirectional primitive is
module bidir_io (
input wire in,
input wire oe,
output out,
inout wire io
assign io = oe ? in : 1'bz;
assign out = io;
endmodule
I only use the 'out' to sense any changes to 'io' pin. So I'm not sure why the error points to 'io'.
The tri-state logic is burried in the I/O so it's not possible to assign a tristate signal directly to another signal. If you take a look at a diagram of the I/O logic of the FPGA this will become more clear.
So if I need to read in the state of the bidirectional line, how do I do it without connecting anything to it?
Take a look at the design examples page on www.altera.com and search for "tristate". You'll find examples of what you are attempting to do.
Thank you all.. I understood the issue after reading the above mentioned Altera doc link.
Ram
