17258 Discussions
Trouble hardcoding an initial value of flip-flop on power up.
Hi All,
I'm using a Max 10 FPGA.
I'm having trouble instantiating a d flip flop initially set to '1'.
From the altera.altera_primitives_components.all I am instantiating the following:
component dff
port (
D : in std_logic; -- Data Input
CLK : in std_logic; -- 100 MHz clock
CLRN : in std_logic; -- Clear Input
PRN : in std_logic; -- Preset Input
Q : out std_logic -- Output Data
end component;
But there is no generic that let's me hardcore a '1' there?
I want to shift in 0's when the power is recycled (by tying the pin to ground) and
so I need the initial value of the register to power up to '1'.
Thank you for your help.
Bryan Kerr
Electronics Engineer
Why are you using the primitives? why not infer the register, because then you can apply the initial value yourself:
signal q : std_logic := '1'; -- initial value .... process(clk) begin if clrn = '0' then q <= '0'; elsif prn = '0' then q <= '1' elsif rising_edge(clk) then q <= d; end if; end process;
If a register has async clear, it often uses this as the power on value if none is specified.
If you have to use the primitives, I think you can assign the power on value in the project assignments. You will need to compile the project to get the register path from the node finder.
Consider that simultaneous asynchronous reset and preset isn't supported by MAX10 logic elements. It has to be emulated by a combination of DFF and combinational logic, including latches.
The dffeas primitive component and the ff wysiwyg component have a power_up generic, by the way.
