17252 Discussions
USB Blaster Driver from Quartus Prime not working on Windows 10
Hi All,
I am using just the USB-Blaster Driver from Quartus Prime.
The primary mode of application for the USB Blaster is to run JTAG tests, that is done by a 3rd Party Vendor. The driver version used is 2.12.0 (packaged with Quartus 17.0).
So, when I try to run the tests on Hardware on Windows 10, it just crashes the system and causes reboot. I would appreciate any insight on this.
Please let me know in case you need any other info.
Harsha
