17253 Discussions
USB Blaster cannot be selected
KarelSterckx
If I execute the following sequence in Quartus Prime
  1. Quartus Prime window -> Tools -> Programmer
  2. The Programmer dialogue appears
  3. On the left, underneath the menu bar, click Hardware Setup
  4. In the Hardware Setup dialogue that appears, to the left of Currently Selected Hardware, select USB Blaster
The USB blaster is not there. What needs to be done to be able to select it?
KarelSterckx
To my embarrassment, I accidentally found out that the driver is installed when the PC is rebooted with the development board switched on and connected to a USB port.
Anyway, perhaps someone may find this simple solution useful.
KarelSterckx
USB driver Intel(R) USB 3.0 eXtensible Host Controller is installed and DE10-CV development board was switched on.
NurAiman_M_Intel
Please try to uninstall and reinstalled the USB blaster driver. Make sure the driver is correctly installed.
Aiman
KarelSterckx
 Thanks for your reply. The driver has been correctly installed. Hence, that is not the solution I am afraid.
KarelSterckx
Apologies, I was too hasty in my reply. In 'Control Panel' -> 'Printers and Devices' -> 'Bluetooth and Devices', under 'USB Blaster', it is mentioned that the 'Driver is unavailable'
Does anyone know where to download the driver?
KarelSterckx
KarelSterckx
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
