16642 Discussions
Unable to place RAM cells in design
Hi folks,
I'm trying to work on an SoPC design. I've used my architecture as an IP and inserted it onto the SoPC having Nios II CPU, jtag-uart, interval timer, on chip memory, and a pio.
I'm trying to fit this device onto a Cyclone II EP2C20F484C7.
My IP's architecture uses DPRAM cells, around 32 of them with a depth of 150 bits each accessed 1 bit at a time. So the total usage during its compilation was ~ 4096 memory bits.
Now, after generating an SoPC, when i try to compile it, i get the following error:
Error: Cannot place 265 RAM cells or portions of RAM cells in design.
Please advice me as to what I should be doing.
btw, I'm an amateur as far as the quartus tool and SoPC are concerned.
So you have 32 dprams, each is 1 bit wide and 150 bits deep?
That is correct.
seems to me that each of the 32 dprams should only use 1 M4K.
http://www.altera.com/literature/hb/cyc2/cyc2_cii5v1_03.pdf shows that the M4K can be configured to 4K x 1. It also show that the EP2C20 has 52 M4Ks. This would make me assume that the rest of the system is using the other 233 M4Ks(error message says cannot fit 265 RAM CELLS... 265 - 32(from the IP) = 233). What is the size of the on chip memory? Are there multiple instances of your custom IP?
I've set the size of the on-chip memory as 20kb.
No, there's only one instance of my IP in the SoPC.
The design of the architecture is such that I'm using 32 components which in turn instantiates the identical DPRAM cells having 150 bits capacity each read/written 1 bit at a time.
Total memory bits used by the IP is 4800 out of the available 239616 bits.
Take a look at the Compilation Report and look under Analysis & Synthesis -> RAM Summary. See if there is anything that jumps out at you. Maybe copy and paste it here. It doesn't show the M4K usage like the Fitter -> RAM Summary does but it may give clues.
The 32 DPRAMs at 150 x 1 will use up 147456 ram bits because they are blocked off in 4k blocks plus parity. Each M4K is 4608 bits(4096 + 512 parity bits). Each of your DPRAMs will use one M4K, thus, 32 * 4608 = 147456 bits. Thats 61.5% of the available ram bits.
This is the summary of my IP's compilation report:
--- Quote Start ---
Total logic elements 1,859 / 18,752 ( 10 % )
-- Combinational with no register 777
-- Register only 224
-- Combinational with a register 858
Logic element usage by number of LUT inputs
-- 4 input functions 492
-- 3 input functions 635
-- <=2 input functions 508
Logic elements by mode
-- normal mode 1138
-- arithmetic mode 497
Total registers* 1,082 / 19,649 ( 6 % )
-- Dedicated logic registers 1,082 / 18,752 ( 6 % )
-- I/O registers 0 / 897 ( 0 % )
Total LABs: partially or completely used 133 / 1,172 ( 11 % )
User inserted logic elements 0
Virtual pins 0
I/O pins 45 / 315 ( 14 % )
-- Clock pins 1 / 8 ( 13 % )
Global signals 2
M4Ks 2 / 52 ( 4 % )
Total memory bits 4,800 / 239,616 ( 2 % )
Total RAM block bits 9,216 / 239,616 ( 4 % )
Embedded Multiplier 9-bit elements 0 / 52 ( 0 % )
PLLs 0 / 4 ( 0 % )
Global clocks 2 / 16 ( 13 % )
Average interconnect usage 2%
Peak interconnect usage 4%
Maximum fan-out node clk~clkctrl
Maximum fan-out 1039
Highest non-global fan-out signal quad16:q16|nlfsr10:nlfsr_10|wradd[4]~731
Highest non-global fan-out 520
Total fan-out 8026
Average fan-out 2.72
--- Quote End ---
Also, could you tell me how much of on-chip memory i should be allocating so that the SoPC would fit. I have no memory requirements?
This is the resource summary of my SoPC:
--- Quote Start ---
Total logic elements Not available
Total LABs Not available
Virtual pins 0
I/O pins 22 / 315 ( 7 % )
-- Clock pins 0 / 8 ( 0 % )
Global signals 14
M4Ks 86 / 52 ( 165 % )
Total memory bits 150,464 / 239,616 ( 63 % )
Total RAM block bits 396,288 / 239,616 ( 165 % )
Embedded Multiplier 9-bit elements 4 / 52 ( 8 % )
PLLs 0 / 4 ( 0 % )
Global clocks 14 / 16 ( 88 % )
Maximum fan-out 2954
Highest non-global fan-out 695
Total fan-out 29721
Average fan-out 3.86
--- Quote End ---
Apparently, the problem isn't related to the said 32x150 bits DP rather than SOPC memory. The memory requirement is doubled by the Quartus software to fix a Cyclone II silicon bug. This workaround may be unneccessary in some cases and can be disabled then, see the Cyclone II Errata Sheet for details. As a first step, I would reduce SOPC memory until the design fits.
restricted the on chip ram size...it fits now!
thank you people!
Hi there,
I'm not able to run (build) even a simple Hello world program in Nios IDE, since it says the required memory is far more than that provided:
onchip_mem is full (hello_world_3.elf section .text). region needs to be 25984 bytes larger.
Now, when I add 26k to the onchip memory, the design does not fit on the board.
Please suggest me as to what I should do!
btw, this is the resource usage summary
--- Quote Start ---
Total logic elements 3,526 / 18,752 ( 19 % )
-- Combinational with no register 1571
-- Register only 329
-- Combinational with a register 1626
-- 4 input functions 1219
-- 3 input functions 1167
-- <=2 input functions 811
-- normal mode 2551
-- arithmetic mode 646
Total registers* 1,955 / 19,649 ( 10 % )
-- Dedicated logic registers 1,955 / 18,752 ( 10 % )
Total LABs: partially or completely used 279 / 1,172 ( 24 % )
Virtual pins 0
Global signals 14
M4Ks 48 / 52 ( 92 % )
Total memory bits 178,880 / 239,616 ( 75 % )
Total RAM block bits 221,184 / 239,616 ( 92 % )
PLLs 0 / 4 ( 0 % )
Average interconnect usage 7%
Peak interconnect usage 19%
Maximum fan-out 1714
Highest non-global fan-out signal quad_sys:quad|quad16_0:the_quad16_0|quad16:the_quad16|nlfsr10:nlfsr_10|wradd[4]~731
Total fan-out 17597
Average fan-out 3.17
--- Quote End ---
Thank you!
Try to uncheck the option "auto ram replacement" under "assignments -> device -> analysis & synthesis settings"
It would probably help more if you included the summary of the compilation of the SOPC system not just the ip. In the compilation report there is a section called "fitter -> resource usage -> resource utilization by entity" where you can check exactly which resources every component uses. That can maybe help you to find your problem area.
//Ola
I already mentioned, that the doubled RAM block requirement is due to a Quartus workround for a silicon bug. However, with Rev. B and later devices the cycloneii_safe_write parameter can be changed from default restructure to verified_safe to double the block count available for dual port RAM.
I included an SRAM in the SOPC builder and now the problem does not persist.
The next hurdle is programming the SoPC. How do i go about programming the Nios II processor to interact with my IP?
