17255 Discussions
Unable to scan device chain
Hi all,
I´m relativ new with the CPLD´s, and now I have the first problem with programming the device. It´s a EPM570T100.
I ´m using a Elcamino PICoMax to programm the device. This works with one of my boards, so the programmer seems to be o.k. But I have another board which has always this error message when trying to Auto-detect:
Unable to scan devive chain. Can´t scan JTAG chain......
I checked twice every pin, VCC, GND and the 4 JTAG pins... no error found. I also measured with the Scope at the 4 pins. I see a signal on all 4 pins, but I´m not sure if they are right...
My three questions:
Any ideas what my problem is?
What do I have to see at this pins?
How do I use the debugger to find the error?
Richi
What devices are in the chain on the board that doesn't work ? Do any devices have a TRSTn pin ? If so, this pin normally requires to be held low for normal operation and raised high for JTAG chain. Holding it low will break the chain.
Hi, No other devices in the chain.
But I fixed it:
1. My Laptop seems to have problems with the parallel port. The other PC works now
2. I had to put more caps to the supply. 4x 100nF are not enough. Now I have 6x 1µF and it works!
Good diagnosis
I've also had problems with ground loops and laptops. Some (perhaps older) laptops have 2-pin mains adapter connections, which means there is no earth. So a substantial AC leakage current can run round the JTAG circuit ground if the DUT is properly grounded. There are at least two ways to fix this: 1 get an AC adapter with a properly connected ground; run a substantial ground cable from the parallel port to the DUT's ground.
Just solder 4 x 10nF Capacitors from all 4 Data/Clock wires to ground and everything is fine!
